TD5 distribution chain
If your meaning timing chain, then i would change it when it gets noisy, although LR do say that at roughly 200k's you should replace it as a service item. Duplex Chains do last a very long time, you could inspect the slack in the chain just in case its stretched so far that the auto adjuster is at its max setting but i believe you would have running issues if it got that bad.
  • 1 month later...
