ajh Posted December 8, 2010 Share Posted December 8, 2010 I am trying to determine what thickness/diameter of tubing (and type of tube) I need to match the top weight rating for a set of Zu Alloy wheels which is 1400kg each and it will be a single axle trailer, is the wheel weight rating of each wheel added together for a maximum load or for an off-road trailer is there a normal ratio considered sane? I'm thinking that having a GVWR of around 2500kg would be ideal (I'm not likely to get it that high, but build to last.) I was thinking about using coil suspension with trailing radius arms and a panhard rod so that I can later equip it with air-bag helper springs (part of a forced articulation system that's about item 100 on the todo list for the vehicle) and any insight would be appreciated. Quote Link to comment Share on other sites More sharing options...
