Junglemist Posted April 18, 2011 Share Posted April 18, 2011 I have an LT77 gearbox with the slave cylinder removed. With the slack taken out by pressing in on the push rod how far should the push rod stick out past the housing? Thanks. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 18, 2011 Share Posted April 18, 2011 About 20-25mm if I remember correctly. Les Quote Link to comment Share on other sites More sharing options...
Junglemist Posted April 18, 2011 Author Share Posted April 18, 2011 That's what I was afraid of. I just installed the engine and I must have somehow messed up the alignment of the clutch fork on the bearing. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 19, 2011 Share Posted April 19, 2011 The fork may have come off the thrust bearing. The silly little clip that's supposed to hold it in place is no good at all. Les. Quote Link to comment Share on other sites More sharing options...
Junglemist Posted April 21, 2011 Author Share Posted April 21, 2011 I was able to move the fork around correctly and got the slave cylinder back on and bled. Thanks for the information on the spacing. I will watch the alignment of the fork better next time. Quote Link to comment Share on other sites More sharing options...
