godzilla84 Posted August 27, 2011 Share Posted August 27, 2011 Hi all. I have recently had a LOT of welding work done on my 5 door 300tdi discovery and to reduce the costs I decided to remove the interior myself and found that the sound dededening material was soaking wet and was te main reason for the corrosion. I use the land rover off road including a bit of wading so I wondered if anybody can recommend a method of noise reduction that will not retain water if it gets wet or is easily removed prior to going in water. Quote Link to comment Share on other sites More sharing options...
