biggles Posted October 8, 2011 Share Posted October 8, 2011 Ive just got an xplore ix104 tablet to run memory map, it didn't come with a power supply to run in the truck, tho ive one from an old dell xps, the xplore is rated at 20 vdc output at 3.5 amps, the lind supply (same fitting as the dell) is rated at 20vdc output, 6.0 to 6.5amps pk, question is to those who know there amps is, will the xplore be ok with this at both 12 volt supply in the defender and 24 volt supply in the other truck (the 44 ton one) thanks for any help Quote Link to comment Share on other sites More sharing options...
Mark Posted October 8, 2011 Share Posted October 8, 2011 Current is drawn rather than supplied. That is, something that can supply 6.5A will happily power something only drawing 3.5A. provided the plugs fit, it sounds like it should be ok. The lind supplies are good quality bits of kit. Cheers Mark Quote Link to comment Share on other sites More sharing options...
biggles Posted October 9, 2011 Author Share Posted October 9, 2011 Understand now, thanks for quick reply Quote Link to comment Share on other sites More sharing options...
