mcc1979ian Posted June 26, 2012 Share Posted June 26, 2012 ok so im fitting a 3.9 efi v8 into my 90 (currently disco 200tdi) and wonder if i should be using the 1 or 2 hole fuel tank and also what pump should i be running (part numbers if poss), currently theres no fuel tank as the last one was pee'ing oot so im gona have to replace it anyway. Quote Link to comment Share on other sites More sharing options...
muttleyd Posted June 26, 2012 Share Posted June 26, 2012 My 3.9 setup is a 2 hole tank with a modified range rover and a modified PRC8318 range rover pump. The range rover pump has been extended to be the same length as a standard defender pump. I should say I have not run this yet as I am still mocking up and wiring the megasquirt Quote Link to comment Share on other sites More sharing options...
