Discovery 2 brake fluid change
RangeyRover
Just changed the brake fluid on my discovery 2 v8.
Came out black for the first 2 litres.
Never seen fluid that bad before.
I used the nanocom and opened the inlet and outlet valve in the abs block and ran the pump to bleed the brakes. Very effective, but I'm not sure if that's the correct way to bleed the abs brakes? Anyone know the correct procedure?
I will have to buy more fluid Anyway as the fluid is not yet clean enough.
Is anyone is looking like I was for the brake fluid capacity
It is at least 2.5L if you exercise the abs valves.
