matt1295 Posted December 30, 2012 Share Posted December 30, 2012 hello when i turn the ignition on the light comes on the dash and goes out when i start the freelander and put the HDC on theres no light i seen there can be a problem with the switch and checked that but that hasnt cured the problem either what else could it be Quote Link to comment Share on other sites More sharing options...
Freelaner Posted January 4, 2013 Share Posted January 4, 2013 Are you driving whilst in hdc? It only works in 1st and reverse abd will cancel if you press the brake or accelerator Quote Link to comment Share on other sites More sharing options...
matt1295 Posted January 4, 2013 Author Share Posted January 4, 2013 turns out i have major issues with this system as i have the HDC and TC lights on (previous owner removed bulbs) i have checked the wiring to my knowlege and im thinking the black box under the drivers seat is faulty are these common for failure Quote Link to comment Share on other sites More sharing options...
tiago_silva Posted January 5, 2013 Share Posted January 5, 2013 That is a common failure at least for me. In December it happened me twice. The problem was solved by changing the brake switch under the brake pad. It's cheap and easy to solve! Quote Link to comment Share on other sites More sharing options...
matt1295 Posted January 6, 2013 Author Share Posted January 6, 2013 my brake pedal switch is only the 2 pin one and my brake lights work and was told this wouldnt cause my problem due to been the 2 pin version switch Quote Link to comment Share on other sites More sharing options...
