V8 Sensors?
4x4Jago
Got the trigger wheel on tonight and started stripping the Rover loom out. Figured the injector live and firing wires and just wondering about the rest before I rip it all out..
What are the sensors in the pic for? I see No 1 is in the fuel rail, temp? Question is, do I need any of them for the MS?
Also can anyone identifiy which wires are which for the TPS? Theres a red, a yellow and a green. I guess the red is live but which one is earth and which one is signal?
Thanks,
Steve
2 is for your temp gauge in the car. 3 is coolant temp as and this does connect into ms. You don't need 1 its fuel temp or pressure. There is a wiring diagram on here somewhere which will show you the connections for tps as I can't remember them at the moment
