discotower Posted August 9, 2013 Share Posted August 9, 2013 Hi All First post so here we go my nearside stabilizer connecting rod bolt sheared off today with half the bolt in the housing. 56 plate Disco un usable when you reverse the wheel looks like its going to fall off limped in to kwik fit thinking rod had just come loose and I saw the bolt still in the housing they say I will need a ne hub and a load of parts that come with it had a full list of parts from landrover on a fax say whats needed £480.00 quid to get back on the road anyone else had any issues with this stabilizer rod just glad it broke on a A road as on the motorway could off been realy bad all comments welcome Quote Link to comment Share on other sites More sharing options...
Confused Posted August 11, 2013 Share Posted August 11, 2013 I'm not familiar with the disco 3 but have they given any reason for not being able to remove the bolt from the housing? Whatever this housing is, if it comes off the vehicle, even the worst machinist should be able to remove the sheared bolt and at worst helicoil the hole. Good luck whichever way you choose to go. Quote Link to comment Share on other sites More sharing options...
