Compressor lacks air
mcc1979ian
Ok so last night i was out in the garage and went to use my compressorso i turns it on as per usual, lets it build up, then stops as usual once up to pressure.
Once i started using it the pressure suddenly drops and theres a sound like air has just rushed through the tank then i left with very little pressure as the motor dosent kick back in straight away.
Any ideas fellas?
