petrolhead63 Posted June 24, 2016 Share Posted June 24, 2016 whilst doing the exhaust manifold I have been giving the truck a birthday ;0) The wastegate I thought was a bit sticky/could jam so have worked it until it is nice an loose. The actuator unit seems to have a slightly bent rod..is this normal? Is there any way I can check it is ok Finally, was going to pop on a boost gauge I have, is this best Tee'd into the little hose which comes off the intercooler pipe to the modulator or into the hose near the actuator on the turbo? Quote Link to comment Share on other sites More sharing options...
