JimDay Posted July 2, 2016 Share Posted July 2, 2016 I have a 1995 Disco 1 with the 2 button remote fobs but one of the fobs has stopped working new battery fitted but did not resolve the problem is it possible to program another fb from a Rover 200 to work on my Disco. I'm sure I've read it somewhere that this can be done but cannot find any posts referring to this I've also read in the handbook about a code using the door key in the lock & turning the key so many turns to the left & so many turns to the right to over ride the immobiliser but sadly I don't have the code fro this as it's an old vehicle any info regarding this method has been long lost Any help or advice much appreciated Quote Link to comment Share on other sites More sharing options...
Tal Posted July 2, 2016 Share Posted July 2, 2016 Have you tried putting a bit of aluminium foil in the fob to make sure the battery contact is good? Could be as simple as that, I've had several fobs be seemingly dead but brought back to life with a bit of foil. Tal Quote Link to comment Share on other sites More sharing options...
JimDay Posted July 9, 2016 Author Share Posted July 9, 2016 No I hadn't tried the tin foil trick but have since tried it with no difference Quote Link to comment Share on other sites More sharing options...
Tal Posted July 9, 2016 Share Posted July 9, 2016 Back to the techy guys here I'm afraid I get lost when it's no longer mechanical. Quote Link to comment Share on other sites More sharing options...
hangover Posted July 14, 2016 Share Posted July 14, 2016 Usually the places that sell the batteries can test the fob to see if its actually emitting a signal or not. Quote Link to comment Share on other sites More sharing options...
Tal Posted July 15, 2016 Share Posted July 15, 2016 I guess here a landrover dealer might be able to test it. On a side note I got my last battery from one of those bank PIN calculator things (CR2032) Quote Link to comment Share on other sites More sharing options...
