bootneckdave Posted December 29, 2011 Share Posted December 29, 2011 hi guys recently bought a 56 plate disco 3 with 58,000 miles hse spec just had the suspension drop onto what i can only describe as its bump stops and had the amber suspension warning light illuminate ? is this the start of a lot of problems or something simple ??? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 30, 2011 Share Posted December 30, 2011 Quite possibly - it is a D3 after all. Just wait till you have to change the heater plugs Forget DIY fixes - you need to plug it into a diagnostic computer. The things are so damn complicated that any one of a dozen things could have caused it. You need some stored fault codes (which there will be, if a light has come on) to know where to go from there. I'd guess from experience that the most likely possibilities are a failed ABS speed sensor (which for some reason triggers panic mode in the suspension) or a failed height sensor / valve / compressor / pipe / spring / wiring harness in the air suspension system. Dropping to the bump stops is a sort of fail safe thing which it does if it becomes all confused and emotional. Think of it as having PMT Quote Link to comment Share on other sites More sharing options...
