ajh Posted September 1, 2017 Share Posted September 1, 2017 Has anyone done a modification to get the full range of tilt available on a Disco2 steering column? There are a lot more teeth on the tilt lock than can be engaged with the factory set-up with what 1 degree of tilt? Why did they even bother except to be able to claim 'tilt steering'. I'm using the column in a Tomcat, so want to be able to actually get enough room to get in and out without needing a disconnect on the wheel. Quote Link to comment Share on other sites More sharing options...
ajh Posted September 1, 2017 Author Share Posted September 1, 2017 OK, so the modification itself turns out to be trivial. However I'm having some issues getting the short top steering column out of the housing. I've got the clip out, but am a bit reluctant to just pound on the U-joint directly... is there some trick to getting it out? Quote Link to comment Share on other sites More sharing options...
ajh Posted September 4, 2017 Author Share Posted September 4, 2017 So, pounding on it to get it out seems to way. Quote Link to comment Share on other sites More sharing options...
