Bobpmoore Posted December 16, 2017 Share Posted December 16, 2017 I have a 2003 freelander. It has a missing pipe from the heater motor to the driver side windscreen demister. I have been told that the clutch pedal and cylinder need to be removed to fit the pipe. Is that correct? Also anyone know the part number for the pipe? Thanks Quote Link to comment Share on other sites More sharing options...
Wicklow Landie Posted December 17, 2017 Share Posted December 17, 2017 On 12/16/2017 at 9:00 AM, Bobpmoore said: I have a 2003 freelander. It has a missing pipe from the heater motor to the driver side windscreen demister. I have been told that the clutch pedal and cylinder need to be removed to fit the pipe. Is that correct? Also anyone know the part number for the pipe? Thanks Hi Bob, not too sure as to what needs to come out but if you need a pipe I have one here which I am happy to send you F.O.C. Its from a 2002 Td4 that I have here broken for parts. They are a rigid pipe section unlike cars of old which had flexi pipework. I can look tomorrow and try calculate what would have to be removed to get it out. Quote Link to comment Share on other sites More sharing options...
