uninformed Posted May 16, 2018 Share Posted May 16, 2018 Hi all , I require some measurements if possible. The width of a disc brake Sals 110, axle housing flange to axle housing flange The thickness of the axle housing flange on a DRUM brake 110 Sals The thickness of the mounting surface on a 1995> disco rear stub axle - FTC3188 (with the scollop cut out for ABS) - also defender rear 2007 onwards cheers Serg Quote Link to comment Share on other sites More sharing options...
