DirkR Posted June 17, 2018 Share Posted June 17, 2018 Hi there, Can anyone tell me how the rear floor cross-members are best separated from the floor? I want to clean them and give them a lick of chassis paint. I see some rivets in the middle section that I can drill out. But on the sides, I don't see how it's fixed. A sort of screw or a sort of nail? I has a flat surface... Since I want to re-use them I wan't to make sure I do it right. Many greetings & thanks for your clarifications! Dirk Quote Link to comment Share on other sites More sharing options...
Flailbasher Posted June 17, 2018 Share Posted June 17, 2018 Hi Dirk, I rebuilt my series 3 about 4/5 years ago. From what I remember I just drilled out the rivets as you suggest and they came straight off. (Apart from a lot of galvanic corrosion) hope this helps a bit! Tom Quote Link to comment Share on other sites More sharing options...
DirkR Posted June 27, 2018 Author Share Posted June 27, 2018 Hi Tom, Thanks for your input. I ended up by drilling the ones in the centre of the panel out and grinding off the ones on the sides. All went well. Many greetings, dirk Quote Link to comment Share on other sites More sharing options...
