alesak Posted February 6, 2019 Share Posted February 6, 2019 Good morning, i'm converting an RHD Disco 1 (vin KA04xxxx) to left hand drive. Car is now fitted at right hand side with swivel pin housing shown in pics, it has grease lubrification, no ABS and it lacks of redundand steering arm, so need to change it. All measures are shown in pics, brake calipers bolts are 12,0 mm diameter and 35 mm long (so for bigger caliper model i think). Don't know if car is fitted with original front axle, however it is 10 splines. I have some doubt about the correct item to order: FTC5298, FTC2522, FTC2526 or other? Which is the difference between them, as in pic they seems perfectly the same? Many thanks Quote Link to comment Share on other sites More sharing options...
