Holmkiern Posted February 24, 2020 Share Posted February 24, 2020 Hi, I got an issue regarding the starter. First thought it was relay by the fuses that was the starter relay but wires was too small to be the one. Found a relay behind the instrument,just behind voltage meter and thought that was for the starter but no. I was able to start without relay in socket. I know I need to change ignition switch since I found I was able to start when moving the wires behind column but just want to make a fix solution while ordering new switch and want disconnect relay to avoid short cut. Car is 110 1987 2,5 N/A All best/Johnny Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 24, 2020 Share Posted February 24, 2020 The relay only triggers the solenoid (part of the starter) so the wires are fairly small. From memory it is one down behind the fuses. If your worried about shorting just disconnect the battery. Mike Quote Link to comment Share on other sites More sharing options...
Holmkiern Posted February 24, 2020 Author Share Posted February 24, 2020 Hi Mike, I know the function of the relay but size of cable does not match the size connected to starter. My idea was to have an extra button connected to relay and controll it separately and therefor wanted to disconnect it from relay. Are there more places with relays then behind dash and fuses? Quote Link to comment Share on other sites More sharing options...
