Benjamyn999 Posted December 13, 2020 Share Posted December 13, 2020 Is it possible to change the light in the Td5 clock. I have replaced all other gauge lights with blue tint LED and would like to do this on the clock, but the unit appears to be sealed. Is there a knack to opening it - and I do, what is the trick? Quote Link to comment Share on other sites More sharing options...
western Posted December 13, 2020 Share Posted December 13, 2020 found this info in this thread Td5 clock illumination Quote The clock on a Td5 has 4 small led's on the printed circuit board within the clock. It is possible to strip the clock and replace with coloured, I did mine today. They are soldered onto the circuit board so you have to unsolder the originals and solder on the new. It's fiddly but not difficult, I only swapped 2 as that was enough to give off enough colour as the other clocks. Also the green lighting of the originals comes from a green layer on the back of the clock face, this I just carefully sanded off with a fine sandpaper. Quote Link to comment Share on other sites More sharing options...
Benjamyn999 Posted December 19, 2020 Author Share Posted December 19, 2020 Thank you. My afternoon’s work is now planned! Quote Link to comment Share on other sites More sharing options...
