NicTheOrange90 Posted January 22, 2007 Share Posted January 22, 2007 Ive got a civvy light switch and want to replace the old NATO one as I want to use space in the middle of the dash.Previous advice was that there would be a loom behind the steeriing column to plug into (there is indeed - thanks). Also advised to join two wires from old NATO switch together, but er cannot remember which ones... As is dipped headlights work OK, but no front sides. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 23, 2007 Share Posted January 23, 2007 Do your tail lights work? if so, then you need to connect together the thin red wires. one goes to the front sideligts and one to the rear. i can email you over the military wiring diagram if its any use? (90 or 110 diesel? or 130 V8) Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted January 23, 2007 Author Share Posted January 23, 2007 Do your tail lights work? if so, then you need to connect together the thin red wires. one goes to the front sideligts and one to the rear.i can email you over the military wiring diagram if its any use? (90 or 110 diesel? or 130 V8) Thanks Jim, will give the thin red ones a go in the next few days and let you know. Quote Link to comment Share on other sites More sharing options...
