pritch1 Posted February 19, 2007 Share Posted February 19, 2007 I had the same problem with my 90 i ended up hammering on a smaller socket and using an arc welder to run weld through the hole into the inside of the socket (make sure you weld it in the right place to get a breaker bar onto it) this joined the bolt and socket and i had no worries about gettin weld on the caliper by accident. The heat helped as well and a quick jump on the breaker bar and a sutible length of tube and they were off. 4 sockets are alot cheaper than 300 quid even if you get someone else to weld them on. Quote Link to comment Share on other sites More sharing options...
JST Posted February 19, 2007 Share Posted February 19, 2007 disco series 1 front axle available in somerset i expect he would take £50-£75 for it if you offered that, if int drop me a PM i will PM bakc the gusy number. Quote Link to comment Share on other sites More sharing options...
