nileseh Posted October 20, 2022 Share Posted October 20, 2022 The car is a 2012 LR4, It came without the tow package. I bought the Land Rover original parts to add it, the wiring harness, and the LR040248 receiver, a clever bit that. So now storage, I came to understand that the left rear load space outboard side cavity was available and there is a Land Rover original part to facilitate, LR020002. I bought that, not yet installed, but I can't see how the storage fixture will accommodate the receiver. It does not seem to fit in any possible orientation. Am I missing something here? Quote Link to comment Share on other sites More sharing options...
simonr Posted October 20, 2022 Share Posted October 20, 2022 There's a picture here & some instruction: https://www.disco3.co.uk/forum/fitting-tow-bar-holder-lr020002-186897.html and also this picture found on line: Quote Link to comment Share on other sites More sharing options...
nileseh Posted October 21, 2022 Author Share Posted October 21, 2022 Right. The tow hitch shown here is the type used in the UK, a ball on a curved arm. In the US the standard tow hitch is a ball on a 2" square tube hat is inserted in a 2" socket receiver on the car. The LR4 adapter has the taper insertion tab and pin lock, but instead of a arm and ball, it has a 2" square socket. That leaves the adapter somewhat bulkier than the UK item and it won't fit in the Styrofoam seat of the storage bracket. It's a little odd, because the first image in the graphic install instructions clearly shows a square receiver opening in place in the side storage compartment. I suppose I can cobble the foam to make it fit, but if there is an appropriate device already available I'd prefer that solution. Quote Link to comment Share on other sites More sharing options...
