Gareth Dickens Posted February 5, 2007 Share Posted February 5, 2007 Hi all Put new front leafs on SIII. Now have about 1-2 " difference in height beteen the front and rear of my landy. (Rear lwr obviously as from the whole sagging butt thing.) Can I put 1 of my old blades into the rear springpack? Want to use a long blade so it bends less when taking normal (empty) load but still flexes when bouncing. Quote Link to comment Share on other sites More sharing options...
Gareth Dickens Posted February 5, 2007 Author Share Posted February 5, 2007 Sorry, I always do this. I have 9 blade springs in the front. Will they manage with the Ford V8 in the nose? Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted February 5, 2007 Share Posted February 5, 2007 You would probably find that the Ford V8 (what gearbox are you using?) is no heavier than the standard 2 1/4 or 2.6 landy engines. You can add extra leaves at the rear no problem providing the retainers are long enough. If you have a hydraulic press, or a big hammer and shaped log you can also increase the arch on a few leaves to restore a bit of height. Bill. Quote Link to comment Share on other sites More sharing options...
Tonk Posted February 6, 2007 Share Posted February 6, 2007 you could also put military shackles on the rear of the rear springs, this will raise it by about an inch Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted February 6, 2007 Share Posted February 6, 2007 you could also put military shackles on the rear of the rear springs, this will raise it by about an inch The Military shackles I measured in my shed are 40 mm longer than stock. If the springs were in very good condition and the shackles were close to vertical the gain would only be around 20 mm. but if the springs are well sagged and the shackles sat at a 45 degree or less angle, the gain would be almost negligable. I once bought an old shorty with very sagged springs on to which the owner fitted shackles 10 '' long. These didn't raise the suspension very much but completely screwed up the departure angle. Bill. Quote Link to comment Share on other sites More sharing options...
Tonk Posted February 6, 2007 Share Posted February 6, 2007 i agree, i was just offering another suggestion, new springs is the real answer Quote Link to comment Share on other sites More sharing options...
