JMZ153 Posted May 9 Share Posted May 9 Hi all, I have a 2003 D2 TD5. Basically everything is standard (height, suspension, etc.). I have the famous 3 amigos on and have had the car tested. Diagnostic is saying it is rear left ABS sensor. I’ve changed this but the fault still comes up. Changed the wheel bearing with a new one, still the same. Changed wheel bearing with a second hand (which was good) but still the same. I then changed the main wire to run directly to from the sensor to the box in the dash, this worked for a while then fault came back. Tried another new Britpart sensor, this worked for roughly 1 week and the fault came back. Has anyone had this issue before? Going a little insane here 🤷♂️🤷♂️ Quote Link to comment Share on other sites More sharing options...
