fmmv Posted 11 hours ago Share Posted 11 hours ago The brakes on my (300tdi) 90 seemed weak. They worked fine, there was power assistance, and they felt normal on mild use but an emergency-type stop needed a massive shove on the pedal. The calipers were recently rebuilt, with LOF performance pads. I suspected the servo or vacuum pump might be struggling, so I attached a Mityvac pump to the servo and it would not hold a vacuum. It's not the original servo, it was fitted new in 2010 about 60,000 miles ago, so it has had some use . We are both knocking on a bit, and I thought it needed addressing as if we did have to do a hard stop maybe we wouldn't shove hard enough. I knew the servos are prone to splitting, so I decided to go with a new servo, in the event I went for a LOF dual diaphragm servo kit. When I took the old servo off, I found that rust had crept under the O ring sealing the servo to the master cylinder. I suspect that was the air leak. So I would suggest if you feel the brakes lack the bite they once had but the servo is working, to detach the master cylinder and have a look. The photo makes it look way worse than it actually is, it seems to be just paint missing and I think a clean up, and new O ring would restore the power. 2 1 Quote Link to comment Share on other sites More sharing options...
fmmv Posted 11 hours ago Author Share Posted 11 hours ago Of course, one other thing on a 300tdi is the vac pump exhausts into the crankcase, so an air leak means air is constantly pumped into the crankcase - not good. Quote Link to comment Share on other sites More sharing options...
Maverik Posted 11 hours ago Share Posted 11 hours ago Good bit of info sharing 👍 On this same topic *different vehicle - being a D2 (Td5), but I also found I had poor emergency stop type situations happening, on checking out the vacuum circuit, the previous owner had removed the EGR system, but not done a great job of sealing up the supply ports for the EGR solenoids etc thus the vacuum circuit wasn't tight, after I fixed it properly, it vastly improved brake performance. 1 Quote Link to comment Share on other sites More sharing options...
