yellow Posted February 19, 2007 Share Posted February 19, 2007 I am planning to build up my 110 again, a bit 'from scratch'. To keep things in or under budget, I was wondering whether I could use the body off a 109, the axles of a Disco I/II or RRC, etc... The papers and chassis I have are from a 1984 110 Hardtop diesel, but I want to go stawagand a more powerful diesel Early 110s had a selectable 4x4 setup,which I might want to re-install. How would I do this? Alternative would be to buy a pre-1965 109 stawag, coil-spring the chassis, and dunk in a 300Tdi or TD5. (Can I keep the grill mounted lights?) Any thoughts on this? Quote Link to comment Share on other sites More sharing options...
western Posted February 19, 2007 Share Posted February 19, 2007 Very few early 110's had the selectable drive set-up, it was drpped by LR after only a few sales, I've only ever seen 1 in France about 7 years ago, the transfer box is different to a standard permanent 4x4 drive 110 & I suspect these 'selectable' boxes & front hubs are very difficult to find, Body from a 109 wouldn't look right as the rear wheel would be to far back in the wheel arch, Discovery rear axles are not rated for a 110's maximum gross weight, you would have to get the completed vehicle approved & a new VIN plate showing new axle & gross weights from the relevant authoriteis. easier would be to rebuild the existing vehicle but fit the Series set back front panels, but I would just stick with the normal 110 panels. Quote Link to comment Share on other sites More sharing options...
