pinny Posted March 4, 2007 Share Posted March 4, 2007 i have water coming in it appears to be coming between the point where the roof is fixed to the sides at the same level as the gutter if i dried it all probably silicone would seal it it appears to get in where the original sealer has become wet cracked it is probably wicking water through the seal any suggestions other than silicone or a good coat of chlorinated rubber 2 pack paint which is high build so i could put plrnty on any suggestions cheers chris Quote Link to comment Share on other sites More sharing options...
dirtdog Posted May 11, 2007 Share Posted May 11, 2007 I have the same problem with my roof I used silicone it worked for while but the leak is back. I talked to the machanic at my local garage and the roof bars needed tightening up but this mean the roof lining needs to be removed to do it. Quote Link to comment Share on other sites More sharing options...
300bhp/ton Posted May 11, 2007 Share Posted May 11, 2007 If you off road or drive hard on the road then I can see the body moving moving about a bit and would possibly in time break any silicon seal. Where abouts along the roof is it leaking? I know a lot of the guys in the States complain about Discovery's leaking around the rear alpine windows. Quote Link to comment Share on other sites More sharing options...
foxminer Posted May 11, 2007 Share Posted May 11, 2007 i have water coming in it appears to be coming between the point where the roof is fixed to the sides at the same level as the gutter if i dried it all probably silicone would seal it it appears to get in where the original sealer has become wet cracked it is probably wicking water through the seal any suggestions other than silicone or a good coat of chlorinated rubber 2 pack paint which is high build so i could put plrnty on any suggestions cheers chris With regards to your leaking roof, my D2 was leaking from some point on the roof so i sealed the sunroof with duck tape to see if that was my problem.the answer to was no it was still getting in ,my next step was to do the same with the alpine windows, SUCCESS, having found that it was the alpine windows i removed the tape and sealed them with clear silicone. Since then we`ve not had to keep an umbrella in the car . Foxminer. Quote Link to comment Share on other sites More sharing options...
pinny Posted May 12, 2007 Author Share Posted May 12, 2007 eventually cured leak with high modulus silicone dried both sides of guttering after removing plastic trim applied silicone and re fitted trim then sprayed tetrosyl underbody sealant full length of gutter this has been on for about 2 months no water yet hopefully cured prob Quote Link to comment Share on other sites More sharing options...
