foxminer Posted May 6, 2007 Share Posted May 6, 2007 Fuurther to my previous post i forgot to ask,has anyone ever heard or tried of IRONTITE or KALIMEX K-SEAL.Both claim to seal cylinder head cracks and headgaskets.Any help or replies will be greatly appreciated. foxminer. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 7, 2007 Share Posted May 7, 2007 K-seal is a very good coolant leak seal, but I didn't know it also seals gaskets. Ceramic motor seal is the stuff for cracks in the block or head. I have used it on a V8 engine and it worked fine. You have to follow the instructions very carefull as the system has to be clean before you use it and has to be flushed out of the system once it's done it's job. I would suggest you prevent water circulation through the heater matrix while you treat the engine - it can settle in the core and block it. Les. Quote Link to comment Share on other sites More sharing options...
foxminer Posted May 7, 2007 Author Share Posted May 7, 2007 K-seal is a very good coolant leak seal, but I didn't know it also seals gaskets. Ceramic motor seal is the stuff for cracks in the block or head. I have used it on a V8 engine and it worked fine. You have to follow the instructions very carefull as the system has to be clean before you use it and has to be flushed out of the system once it's done it's job. I would suggest you prevent water circulation through the heater matrix while you treat the engine - it can settle in the core and block it.Les. Many thanks for your answer what about IRONTITE do you know of anyone who has used this, it claims to seal cracks in the head.On it`s website there are plenty of good tsetimonials for it. foxminer. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 7, 2007 Share Posted May 7, 2007 That's the same stuff I used. Les. Quote Link to comment Share on other sites More sharing options...
