McS Posted October 12, 2005 Share Posted October 12, 2005 If you have done this, could you please post some pics, schematics, general advice etc etc as its a job for me at the weekend. Cheers, McS Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted October 12, 2005 Share Posted October 12, 2005 Whose EGT gauge? Despite the extra cylinder on your engine, so long as you've got somewhere that sees the exhaust gas from all the cylinders, pre-turbine, and is in a reasonable flow (for transient response) the method is the same for any engine. Fit the thermocouple, run the wire back into the cab and then supply power to the gauge unit. Wire the two together and drive somewhere... Thermogard gauges for the 300Tdi use the EGR port for a nice neat install (unless you use damn great bits of plate as washers... ) but you can mount it direct to the manifold and drill a Jubilee clip to hold the thermocouple if you've not got that luxury. Quote Link to comment Share on other sites More sharing options...
