chrisst2 Posted August 16, 2007 Share Posted August 16, 2007 Hi The air con compressor on my P38 diesel only has one wire connection , according to the ETM this should be a 12 volt feed for the clutch, is it possible to test the clutch by disconnecting the wire and then connecting a 12v straight from the battery ? , if so I assume the clutch will move back/forward each time I connect and disconnect , is this right ? thanks Chris Quote Link to comment Share on other sites More sharing options...
