66gaza Posted September 5, 2007 Share Posted September 5, 2007 Does anyone know for definite if this spicer 5 speed is the gearbox that was used on a Leyland Roadrunner. If it is does anyone know of a cheap flywheel & clutch to fit it to a Cummins (SAE 3) ? which I think was the engine that it was attached to. Gaza ? Quote Link to comment Share on other sites More sharing options...
ciderman Posted September 6, 2007 Share Posted September 6, 2007 Not sure , but IIRC the bell housing separated from the gearbox externaly , The picture shows that it is attached internaly. Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted September 6, 2007 Share Posted September 6, 2007 Does anyone know for definite if this spicer 5 speed is the gearbox that was used on a Leyland Roadrunner.If it is does anyone know of a cheap flywheel & clutch to fit it to a Cummins (SAE 3) ? which I think was the engine that it was attached to. Gaza ? I will have a look at one tomorrow as we have a few old leyland trucks in the yard but the bell housing looks to shallow and the gear shift does not look right to me. Thirsty Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted September 7, 2007 Share Posted September 7, 2007 I have just checked in the yard and our Leyland trucks have a diffrent selector setup, I think the box you have is off something like a Leyland Landmaster.(Long bonnet and gear stick straight up through the floor). Quote Link to comment Share on other sites More sharing options...
66gaza Posted September 7, 2007 Author Share Posted September 7, 2007 I have just checked in the yard and our Leyland trucks have a diffrent selector setup, I think the box you have is off something like a Leyland Landmaster.(Long bonnet and gear stick straight up through the floor). Hi thanks for the replies, I know the bellhousing is shallow on the box but it is SAE3 the same as the bellhousing/flywheel adapter on the engine. What I need really is a flywheel & clutch. The I/P shaft is 1.5" 10 spline, I am toying with the idea of puting it behind a cumins so any more help would be appreciated. Gaza Quote Link to comment Share on other sites More sharing options...
