westcoastlandy Posted October 11, 2007 Share Posted October 11, 2007 hey i have bought a disco out in aus. i have the windows down to keep cool in this head but the head lining seems to have sagged. any ideas of fixing the problem? i thiought of spraying glue through a small hole will a wd-40 straw or using a needel to inject glue up cheers cam Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted October 11, 2007 Share Posted October 11, 2007 If you can locate the steel strengthening ribs that run across the roof (there are 3 or 4 IIRC) you could use short self tapping screws to hold the headlining up. The ribs have about a cm of clearance to the actual roof so plenty of room to screw into.If injecting glue it would have to be on these ribs as the lining doesn't come close to the roof anywhere else. Quote Link to comment Share on other sites More sharing options...
DefcoL Posted October 11, 2007 Share Posted October 11, 2007 hey i have bought a disco out in aus. i have the windows down to keep cool in this head but the head lining seems to have sagged. any ideas of fixing the problem? i thiought of spraying glue through a small hole will a wd-40 straw or using a needel to inject glue up cheers cam don't think that glue will solve your problem unless you get it spot on the cross member. this photo might help Regards Lawrence Quote Link to comment Share on other sites More sharing options...
streaky Posted October 11, 2007 Share Posted October 11, 2007 It would be of great help if you give a dimension of how far back from the windscreen the cross member is. Is the vehicle in the same state of build or has it come along since the picture was taken? I wanted to get a dimension of how far back that cross strut on the roof so I can mount my old Defender overhead roof console up there. Thx. S. Quote Link to comment Share on other sites More sharing options...
DefcoL Posted October 11, 2007 Share Posted October 11, 2007 It would be of great help if you give a dimension of how far back from the windscreen the cross member is. Is the vehicle in the same state of build or has it come along since the picture was taken?I wanted to get a dimension of how far back that cross strut on the roof so I can mount my old Defender overhead roof console up there. Thx. S. IIRC it is located where the roof line rises but in any case I strongly recommend pulling lining down to be sure where it is on yours Yes well finished.. See http://forums.lr4x4.com/index.php?showtopic=12075 and Visit My Website Quote Link to comment Share on other sites More sharing options...
Mark Posted October 11, 2007 Share Posted October 11, 2007 I have the roof lining out of my scrap disco at the moment - I will take some measurements for you, but not till the weekend if thats any help? Cheers Mark Quote Link to comment Share on other sites More sharing options...
westcoastlandy Posted October 14, 2007 Author Share Posted October 14, 2007 hi thanks for the advice will give the screws a go. cheers for the quick response Quote Link to comment Share on other sites More sharing options...
