alfredenewman Posted October 28, 2007 Share Posted October 28, 2007 88 rrc i have now welded front diff and refitted it and had a very good deal with fridgefreezer for some defender front free wheel hubs which i am going to fit to allow me to drive 2wd on the road i now need to source the correct stub shafts bearing in mind speed [i want to go to woodlands next week end] any one know part nos and or source thanks in advance Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted October 28, 2007 Author Share Posted October 28, 2007 88 rrc i have now welded front diff and refitted it and had a very good deal with fridgefreezer for some defender front free wheel hubs which i am going to fit to allow me to drive 2wd on the road i now need to source the correct stub shafts bearing in mind speed [i want to go to woodlands next week end] any one know part nos and or source thanks in advance i am refering to stub shafts not axles why is it put me in front of a key board and my brain disingages Quote Link to comment Share on other sites More sharing options...
nickm Posted October 29, 2007 Share Posted October 29, 2007 is u on about the rrc stubb shats (fit on the outside of the cv about 8 inches long) or dya need defender ones Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted October 29, 2007 Author Share Posted October 29, 2007 is u on about the rrc stubb shats (fit on the outside of the cv about 8 inches long) or dya need defender ones no im refering to the shaft that goes into the cv like a very short half shaft simmilar to the kam fusible stub shafts what i dont know is does any rover have the 8in shaft splined at both ends one end for cv other end for fwhub or do i have to fit defender hubs shafts cvs etc with the shaft part of the cv any imfo greatly appreciated as only been toying with rovers for two years after 35 in the motor trade and boy have i missed out thanks in advance Quote Link to comment Share on other sites More sharing options...
steve_d Posted October 30, 2007 Share Posted October 30, 2007 88 rrc i have now welded front diff and refitted it and had a very good deal with fridgefreezer for some defender front free wheel hubs which i am going to fit to allow me to drive 2wd on the road i now need to source the correct stub shafts bearing in mind speed [i want to go to woodlands next week end] any one know part nos and or source thanks in advance Looking through the parts list RR stub has a cup shape flange on the outer end and spline inboard. Defeneder has spline outer end but appears to be part of the CV joint. Looks to me like you may need to have something machined. Steve Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted October 31, 2007 Author Share Posted October 31, 2007 probs solved i hope used defender half shafts and cvs rrc main hub[the bit with ball] defender outer stub shaft but had to put a spacer in front of bearing thrust washer [2 mini primary gear thrust washers perfic fit] will test sunday under full load will post results Quote Link to comment Share on other sites More sharing options...
nickm Posted November 1, 2007 Share Posted November 1, 2007 one question why would you want to weld up ur front diff ? would of fort your steering's gonna be pants Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted November 1, 2007 Author Share Posted November 1, 2007 ive welded it in stead fiting a diff locker on road i will use rwd only with free wheelhubs the welded diff will not affect the steering off road i have a choice 2 3 or 4 wheel drive on hard ground i will probably use 3wd as the steering will not be affected onlooser conditions mud etc 4wd i will probably get abit of under steer i have done it before on a suzuki and had no probs Quote Link to comment Share on other sites More sharing options...
nickm Posted November 1, 2007 Share Posted November 1, 2007 oh ok wouldnt fitting an lsd on the front been a better option and about the same sort of cost (dont know what you paid for fwh and shafts) atleast u would of had 2 wheel drive on the front Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted November 1, 2007 Author Share Posted November 1, 2007 it would be the better optiom to fit lsd orlocker but i did the whole job for under 100 quid the lsd or locker w ould have been 5 times that theres a lot of beer tokens inbetween the two if i was competing i would fit lockers but just for fun i cant justify it and my mates wont keep me in beer when im skint cheers Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted November 5, 2007 Author Share Posted November 5, 2007 gave it good testing ay woodlands works a treat but 3 wd is def no good all over the place in it so its 4x4 or 2x2 from now on thank for the help and thaks to the fridge for the hubs merrick Quote Link to comment Share on other sites More sharing options...
