Maths model of a differential gearbox
LandyManLuke
For an open diff, surely you just need:
Input speed = ratio * (output speed 1 + output speed 2)
Input torque = (output torque 1 + output torque 2) / ratio
BUT
output torque 1 = output torque 2
And alter equation 3 if you have a torque biasing diff. If the diff is locked, no 3 becomes (output speed 1 = output speed 2)
Or is that not what you meant? :huh:
yuh, I've got those basics too, but
what about when a wheel lifts, there's no torque as there's no resistance. (neglecting drivetrain resistance)
what about marginal traction? speed, and torque, are a function of resistance.
I'm using an electric motor as a prime mover, so speed is a function of voltage and load torque, at that end of the drive train.
Those equations cover it because they're simultaneous. Lift a wheel, output torque 2 = 0.
Output torque 1 = output torque 2, so output torque 1 = 0.
Input torque = (zero + zero) / ratio = 0
This is all capped by the input torque from your motor, which you can relate to the current draw?
(I still think you'll need a very refined model for inertia to up-scale it effectively)
