mpb Posted November 6, 2007 Share Posted November 6, 2007 I mate has given me a GEW9000 to look at. There's a fault with the solenoid pack, its not out-putting power a you'd expect. Ive tested the motor with jump leads, but the motor still doesn't turn. I linked F1 to A & put a +ve to F2 with the earth on the earth bolt. Then did the same but linked F2 & A, but nothing happend. Is there some tests i can do with a multi meter to check the condition of the motor. Ive pulled the motor apart & the commutor rotates freely & the drum rotates. Thankyou in advance. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted November 6, 2007 Share Posted November 6, 2007 You could check for continuity, (and find there is none if the motor really is dead) between F1 & F2, and A and ground. Make sure the terminal posts really are clean, I looked at a motor once where the terminals looked clean, but were in fact covered in oxidisation (not rust) and had v.poor contact. Quote Link to comment Share on other sites More sharing options...
