minivin Posted November 12, 2005 Share Posted November 12, 2005 As I wanted a CB for when off with other people travelling, I decided to knocked-up a base to mount on top of a TUAAM arm on the military rovers: it follows the standard six hole pattern, I've fitted three bolts for the moment as I had some spare 1/4 BSF hex set screws in stainless, but not enough aerotight lock nuts in stainless: one of the holes has had the powder coat stripped-back on the arm and PR5A anti-corrosion compound put between the washer and the TUAAM arm to aid bonding, I'll be adding a proper sheathed woven bonding lead from another screw that I fit and take that down to the chassis to try and maximise the grounding. Dimensions for the disc as follows: When I have a PDF of the proper drawing pack, I'll post a link up! Suspect I'll get moaned at from the military rover people for having something shinny on there, but it's ALLOY <cough> and it helps to slow the corrosion process Quote Link to comment Share on other sites More sharing options...
