Spooner Posted February 11, 2008 Share Posted February 11, 2008 As the weather was nice, decided to take a look at the level of fluid in the swivels last weekend. When I changed the oil for one shot in my 1989 90 there was a drain plug in the swiwel casing which seems to have been removed in the teflon coated ones I have on my 1998 110. In the end I removed the two bolts from the lower swivel and let the (small amount) of oil dribble out and then replaced and refilled with one shot via the square headed bolt on the top of the swivel. Can someone confirm there is no drain plug on my model of 110? Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 11, 2008 Share Posted February 11, 2008 IIRC you are correct, the drain was removed on later models, as they were pre filled at the factory (allegedly for life) Quote Link to comment Share on other sites More sharing options...
Spooner Posted February 11, 2008 Author Share Posted February 11, 2008 IIRC you are correct, the drain was removed on later models, as they were pre filled at the factory (allegedly for life) Cheers - that explains why there was about a syringe full in there then Quote Link to comment Share on other sites More sharing options...
