yogibear47.lee Posted February 19, 2008 Share Posted February 19, 2008 hi i had my 235/85/16 tyres fitted today and they rub on full lock how do i get round this? thanks lee Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 19, 2008 Share Posted February 19, 2008 you need to adjust the steering stops on the hubs, easy job. big bolt at the front edge of the hub, it also acts as one of the mounting bolts for the brake shield. put the steering on full lock, then move it back until there is 20mm (?) clearance between the tyre and the radius arm, then wind the lock stop out on the opposite side to the one that you have measured, ie if you measured the distance on the RH wheel, adjust the LH lock stop (someone will correct me if thats wrong) Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted February 19, 2008 Author Share Posted February 19, 2008 ok cheers will give it a go Quote Link to comment Share on other sites More sharing options...
