easyrider Posted February 27, 2008 Share Posted February 27, 2008 There is a loud whining noise coming from gearbox or diffs, how do i fix this? Quote Link to comment Share on other sites More sharing options...
clbarclay Posted February 28, 2008 Share Posted February 28, 2008 Have you checked oil levels recently in the gerabox, transphere box, axles and front swizels? Quote Link to comment Share on other sites More sharing options...
simon Posted March 4, 2008 Share Posted March 4, 2008 also check the UJ's as they will make a whining noise and wheel bearings. Suggest you jack up each wheel and give it a wobble and also use a scew driver to try to move the UJ's. if all okay then it could be bearing in the gearbox or diff knackered. Sorry to say its a matter of illimination. good luck Quote Link to comment Share on other sites More sharing options...
