Rear Axle part
By quoting a rear Truetrac diff for my 110 SW Puma, some of the suppliers asked for part numbers since LR changed a bit the diff :( !
Does anyone know the part numbers for the crown-pinion-bearings-halfshaft.....I went to the dealer who has the microcat, but last weekend some water came from the roof just over his PC. Of course he would not lend me the cd :unsure:
thanks
M
thanks
M
Hi, i was just searching for another post and i would think the same company could help you (worth a try) www.lrseries.com, if they are no use let me know i use them alot and have recommended them a few times but never hear back if it was any use.
Cheers, james
Hello James:
I did not know that page. Looks like they do not address the issue, which I`m surprised of. The Puma is a total mystery whatsoever. LR made ( I hope for good) several minimal changes, beside the engine, on the prop shafts, front suspension and also diffs. Unless I get into the Microcat I think I´ll have no luck searching for parts.
Thanks
M
