Landy 90 Hybrid Posted March 17, 2008 Share Posted March 17, 2008 Hi all, after plenty of fault finding and thanks to FF, I think it may be the ignition amp that is playing up. I have had a search around on that giant skip that is ebay and cannot find an amp available seperatly, only with a dizzy attached. My amp has two pins like this |-, are there various types of dizzy or just the one that have that type of connection? If so what do I need? I would wait till im home but just thought I would have a look whilst at work. Kind regards Jonathan Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted March 17, 2008 Share Posted March 17, 2008 Is the amp on the Dizzy .............. 35DLM8 ? If so then the amp is cheap .............. you have the old 2 pin version which was replaced with a 3 pin version and comes with a new plug and wiring details. IIRC the amp is about £35 .................the older TVR's eat then for breakfast due to the under bonnet heat...... Just checked .............the part number is STC1184 and they retail at £32.50+VAT In fact I might even have a good used one here, complete with the correct lead.......... Ian Quote Link to comment Share on other sites More sharing options...
Landy 90 Hybrid Posted March 17, 2008 Author Share Posted March 17, 2008 yeah the amp is on the RHS of the dizzy, about the 3-4 oclock position IIRC. I have a spare dizzy from a 3.9, with a 3 prong connector. Do you mean that I can get a lead that converts the 2 pin to a 3, and then use the later ignition amp? Any info would be great, where did you get the part number for? Jonathan Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted March 17, 2008 Share Posted March 17, 2008 Yes, the 2 pin amp is no longer available and has been replaced by the 3 pin amp. The replacement comes with the 3 pin plug and the wiring diagram. STC1184 is the correct part number for the amp................. Ian Quote Link to comment Share on other sites More sharing options...
