big ives Posted March 24, 2008 Share Posted March 24, 2008 the disco 200tdi into my 90 is almost completed, but i am having a problem with the clutch more the lack of clutch. i have used the td clutch which was almost new, the td thrust bearing and the fork with the welded bit on it to streghten it. the problem this morning when i tried to run it was i didn't/couldn't get the clutch to operate, if i started the landy in gear then it would move. bleed the clutch, checked the clutch travel as per various posts on this forum, still no joy. next pulled the gearbox and clutch and rechecked all components, everything appears ok i am now thinking the clutch slave cylinder is shagged, again i am using the cylinder from the td any thoughts am i missing anything????? anything else i need to do or check holidays nearly up so i am desperate to get the conversion completed many thanks as i have been asking loads of questions since i started this conversion Quote Link to comment Share on other sites More sharing options...
big ives Posted March 25, 2008 Author Share Posted March 25, 2008 problem fixed, found i had the disco slave cylinder fitted, swapped it back to the one off the TD, bleed the system and hey presto i have a working clutch. just finished fitting all the hoses and have just come back from a test drive, excellent, some difference, 200tdi conversion its the way to go many thanks to all who helped me with info ives Quote Link to comment Share on other sites More sharing options...
