robhybrid Posted April 4, 2008 Share Posted April 4, 2008 If you happened to be spinning one wheel a lot imediatelly before this happend then one of the sun wheels could easily sieze to the cross pin. In my experiance I have seen loads of cross pins break and on closer inspection you can see where the pin started to sieze before giving up. I think std difs were not designed for severe wheel spin but more to suit the slight difference in rotational speed of 2 wheels when you drive round a corner. with a diff out it is interesting to put in 2 half shafts ant turn the input while holding one of the half shafts, the cross pin has to do a lot of work. Quote Link to comment Share on other sites More sharing options...
Young bobtail Rhys Posted April 4, 2008 Author Share Posted April 4, 2008 It went whilst driving around a corner, not all of a sudden just a build up, and then a lot of the front axle shaking until it decided to stop which I think was the pin slowly starting to sieze and once the shaking stopped the pin had locked the diff so the wheels were just scrubbing and not shaking/vibrating. Quote Link to comment Share on other sites More sharing options...
