Erol Posted April 5, 2008 Share Posted April 5, 2008 Dear Members I have a 2002 model ,6 cylinder , 2.5 lt engine Freelander. recently I have noticed a pressure build up in the header tank and some vapour comming from the smal tube connected to the inlet manifold. Engine runs perfect, there is no water in Oil and no Oil in the water. What can be the reason? Do I have a cylinder head gasket leak? Please advice Thanks Erol. Quote Link to comment Share on other sites More sharing options...
jules Posted April 7, 2008 Share Posted April 7, 2008 Dear MembersI have a 2002 model ,6 cylinder , 2.5 lt engine Freelander. recently I have noticed a pressure build up in the header tank and some vapour comming from the smal tube connected to the inlet manifold. Engine runs perfect, there is no water in Oil and no Oil in the water. What can be the reason? Do I have a cylinder head gasket leak? Please advice Thanks Erol. Compression test first what is the temp gauge doing the breathers blocking up on the V6 can cause all sorts of temp problems believe it or not. Quote Link to comment Share on other sites More sharing options...
