Skanny Posted April 8, 2008 Share Posted April 8, 2008 I have been lurking for a while and searching the technical archives. At present i am stripping down an M reg 300Tdi and im currently stuck on removing the Dashboard. I have the passengers side 'loose' and have removed bolts from the nearside bracket where the glove box hinge is and from the passengers side of the transmission tunnel. I have removed the transmission tunnel bracket bolts on the drivers side but cant seem to see where else it is attached on the drivers side, there are that many brackets and plates and bolts i dont know what is attached to what! The steering column is out as are the clocks, im sure im not far away but i dont want to wrench it and damage it Anyone got any words of wisdom - apart from 'dont even attempt to remove a 300Tdi dash!' Thanks in advance Colin. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 8, 2008 Share Posted April 8, 2008 From memory there are two bolts on each side of the tunnel and two more on each A pillar but it is a while since I did mine. It certainly isn't hard to get out but I had a workshop manual in front of me Quote Link to comment Share on other sites More sharing options...
Skanny Posted April 8, 2008 Author Share Posted April 8, 2008 From memory there are two bolts on each side of the tunnel and two more on each A pillar but it is a while since I did mine. It certainly isn't hard to get out but I had a workshop manual in front of me Thanks BogMonster, i have undone the ones you have mentioned, i am awaiting arrival of my haynes from the bay of E at the moment. Hopefully it will clarify things. Quote Link to comment Share on other sites More sharing options...
