Countax Posted December 11, 2005 Share Posted December 11, 2005 Will a Mondeo alternator fit a 200TDi without the need for modifications? I also heard petrol and diesel Mondeo's use different alternators, so does anyone know which one fits best? Thx, Nigel Quote Link to comment Share on other sites More sharing options...
SiWhite Posted December 11, 2005 Share Posted December 11, 2005 I've got a Mondeo alt on my 200Tdi. IIRC it's from a 2.0 litre petrol model - not 100% sure, but it's the only type with a 90amp alt. I had to machine about 4mm from one of the mounting brackets to make it line up with my PAS pump. You may not need to do this as I'm running a V8 PAS pump on a custom mounting plate. The mounting holes are also a different size - LR is smaller than Ford. You'll also need to take to serp belt pulley off and pop yours on. Very easy conversion. Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted December 11, 2005 Share Posted December 11, 2005 I fitted a ex diesel escort alternator to my 90 disco 200TDI just took the old one to scappie as template to check Fitted no probs looked fairly new recon................ but don't know the amperage I think the xr2 has a much larger amperage but the are the same shape and type BTW it had a serpentine pully on it .......simple job to change Steve Quote Link to comment Share on other sites More sharing options...
