trr777 Posted April 21, 2008 Share Posted April 21, 2008 Hi all, passenger door wont open from the inside, had a look inside the door, can't see whats wrong, tried the search directory but still no wiser!!, can anyone put it into plain (simple) english for me please, thanks, Tim. Quote Link to comment Share on other sites More sharing options...
russ3120 Posted April 21, 2008 Share Posted April 21, 2008 hey buddy had a a similar problem with mine, sounds like the little spring has snape on the lock mechanisum, the are pennies on ebay, look under `landrover springs. if your not far from Brecon, I wil open the door for you, well show you how I did it. Quote Link to comment Share on other sites More sharing options...
trr777 Posted April 21, 2008 Author Share Posted April 21, 2008 hey buddy had a a similar problem with mine, sounds like the little spring has snape on the lock mechanisum, the are pennies on ebay, look under `landrover springs. if your not far from Brecon, I wil open the door for you, well show you how I did it. Thanks for the offer, where exactly is this little spring situated? Quote Link to comment Share on other sites More sharing options...
gkm24 Posted April 22, 2008 Share Posted April 22, 2008 Will the door open if you pull up the locking knob? You have to pull up very hard while opening the door. I got the springs off ebay too. Quote Link to comment Share on other sites More sharing options...
russ3120 Posted April 22, 2008 Share Posted April 22, 2008 the springis in the lock mech, you need to remove it, to replace the spring, its not easy if you have big hands Quote Link to comment Share on other sites More sharing options...
trr777 Posted April 22, 2008 Author Share Posted April 22, 2008 the springis in the lock mech, you need to remove it, to replace the spring, its not easy if you have big hands Thanks men, but I've fixed it! no wonder I could'nt see any thing wrong all it needed was the 7mm nut on the end of the rod leading upto the internal handle pinching up a bit to take out the slack, you were right about the large hand problem Russ!!, would of been easier to reskin the bl**dy door!, thanks, Tim. Quote Link to comment Share on other sites More sharing options...
