bigjohn Posted May 11, 2008 Share Posted May 11, 2008 Hi all, when driving on light throttle the car (300tdi manual) seems to jerk a bit sometimes,almost like fuel starvation.It has a new fuel filter,always starts no problem,and pulls good when the pedal is floored.are there any common things to check? . cheers,john. Quote Link to comment Share on other sites More sharing options...
thebiglad Posted May 11, 2008 Share Posted May 11, 2008 Hi all,when driving on light throttle the car (300tdi manual) seems to jerk a bit sometimes,almost like fuel starvation.It has a new fuel filter,always starts no problem,and pulls good when the pedal is floored.are there any common things to check? . cheers,john. Does it have EDC? If it does, there's a reasonable chance your Throttle Position Sensor (TPS) is up the swanny. Quote Link to comment Share on other sites More sharing options...
sotal Posted May 12, 2008 Share Posted May 12, 2008 I doubt it'll have EDC on a manual, not sure what it would be though - if it was a filter blocked or lift pump issue you would expect it to happen on full throttle rather than light throttle Quote Link to comment Share on other sites More sharing options...
